🔒 Locked
Found another D3/iPod bug...
By Misterb · Jan 03, 2008in General💬 11 posts👁️ 1,526 views
Posted Jan 03, 2008 · 06:24 UTC#1
I found that if I'm listening to the iPod on my D3, and I hit the pause button to stop it from playing- that after I turn the car off and then get back in and start the car again, it starts playing the song automatically at startup. Very annoying. Today I drove to an appointment. On the way there, I was rocking out to some music on the iPod attached to the D3. I hit pause, and then turned the car off. I pick up two business guests to ride with me. I start the car, and they're greeted with my D3 blasting in their ears the last song I played! It did it to me a couple more times later on that day, so I I'm not just making it up.
Any logical solutions?
Posted Jan 03, 2008 · 14:21 UTC#2
Turn the volume down before you turn the car off.
Posted Jan 03, 2008 · 16:10 UTC#3
^ What he said.
Posted Jan 03, 2008 · 20:05 UTC#4
That's not a solution. If I've hit the pause button, pause should be pause, and should remain as such unless I push pause again. I suppose I could also smash the unit with a hammer before exiting the vehicle too, huh?
Pioneer. Are you listening? Please test your units next time before releasing them to the public.
Posted Jan 03, 2008 · 20:08 UTC#5
When you pause the iPod, go into the A/V menu and hit off. Then, when you turn on the car next time, the D3 will remember to be in the off selection.
Posted Jan 03, 2008 · 20:09 UTC#6
It's not Pioneer's fault, dude. If you pause an ipod, power down what's hooked up to the data port, then power it back up, it's going to start playing from where it left off. It's going to happen that way REGARDLESS OF WHAT IT'S HOOKED UP TO.
Posted Jan 03, 2008 · 20:44 UTC#7
Exactly. Why didn't you just source it off? It will be in the same spot next time you switch to ipod
Posted Jan 04, 2008 · 00:51 UTC#8
I don't know about that. I've had multiple iPods attached to various sources over the years, and this has never happened to me before.
Posted Jan 04, 2008 · 01:44 UTC#9
Basically, because you're not hitting pause on the ipod itself, but on the device controlling it, the ipod doesn't recall the pause command after it's been shut down and powered back up. Much the same way that if you select say, a playlist from your D3, if you hit the ipod menu button on the D3's display, it will bring you back one step. But, if you turn off the car, and restart it, it will continue playing where it left off, but the menu/back button will be useless, as the ipod doesn't remember the steps it went through to get there.
It basically comes down to a problem of how the ipod handles the interface, not how the interface handles the ipod.
Posted Jan 04, 2008 · 02:17 UTC#10
So what do you do when you blast a CD? It does the same thing you are complaining the ipod does. Just turn it down first!
Posted Jan 04, 2008 · 02:46 UTC#11
.... I suppose I could also smash the unit with a hammer before exiting the vehicle too, huh?....
Please do.
