VSS Wire Location 2007 Pontiac Grand Prix
By dgl867 · Jan 03, 2008in General💬 3 posts👁️ 1,094 views
Posted Jan 03, 2008 · 07:24 UTC#1
I am installing a Z1 in a 2007 Pontiac Grand Prix 3800 Supercharged.
Ive researched the post here and came up with one close match.
Can any one tell me if the Throttle Actuator Control is the same as the VSS for my car? And, could I get a specific location/picture where to find it..thanks
ps. Bestbuy informed me not to worry about hooking it up, the installer stated they dont on their installs. They said the unit will be accurate with in 2 feet with out it. Opinions wanted
also I am installing this with a Gmos 04 module.. I am assuming I connect the RCA connector1 to this RCA on the module for sound.
Any help in this install would be great. [email protected]
Posted Jan 06, 2008 · 14:00 UTC#2
Absolutely not. Please don't be tapping into computer control systems unless you know exactly what you're doing. You could be spending a bunch of money that warranty won't cover.
I'm not familiar with your car. I don't know if you are going to have to access the CAN Bus or not. You could possibly capture it directly off the VSS switch, or even use an ABS sensor in many cases. But I would be asking for some expert help with your car or obtain a factory wiring manual.
Posted Jan 06, 2008 · 14:23 UTC#3
Speed Sense DARK GREEN (AC) AT THROTTLE ACTUATOR MODULE ON TOP OF ENGINE
About as detailed as I can get you.
