I was wondering if the hack is performed the same way if you are used the btb200 bluetooth device and still retain full function. If some one could give me some info on this thanks
Posted Jan 04, 2008 · 16:49 UTC#1
What hack? Are you talking about the D3 lockout bypass? If so, you do the bypass exactly the same. It doesn't affect the performance of the bluetooth unit, as it mutes the D3 through it's IP-BUS cable, not the mute wire on the D3's harness.
