I have the Z2 in my truck with after market sub woofers and amplifier. The amp puts out 600 watts total power which isn't insanely high or anything so my 130amp alternator with the big 3 upgrade should be able to power it no problem, you would think. I did the big 3 upgrade hoping it would fix the problem but it actually had no change what so ever.
I have nothing else after market that would drain any extra power. Also the lights do dim when the truck isn't running but its barely noticeable. I can have the Z2 at 10 volume level and certain songs will cause the lights to dim on the bass hits.
Right now under the sub woofer setting on the Z2 I have it set at 50hz and gain at 0. Equalizer is set to flat and powerful setting set to off. Listening to the music at this setting is like listening without even having sub's but its the only way I can drive around listening to music without my lights dimming at volume level 10. The settings on my actual amp aren't set to anything crazy either, their actually set pretty low.
I'm running 4AWG for the power and ground(which is plenty), and just for a test to see if it was a bad ground I ran an entire separate wire from the amp ground straight to the battery neg and no change.
So my question is, has anyone had this problem before? Is their a different setting on the Z2 that I'm missing that I can adjust that could fix this problem? The only other thing I can think of is replacing the stock battery because with the lights dimming when the vehicle is not running is leading me to believe that it is NOT the alternator. I read somewhere that the stock batteries in my truck are pretty crappy and the only thing they are good for are starting the vehicle in all the different seasons.
Heres some additional info on my stuff:
2007 F150 XLT
RF 2 channel amp 600 watt total power
2 RF 10" 2ohm shallow mount woofers 300rms 600 peak
Any help would be greatly appreciated.
Jom
