Playing DVD's D3
By Cowboy UP · Jan 08, 2008in Problems/Troubleshooting💬 3 posts👁️ 674 views
Posted Jan 08, 2008 · 19:02 UTC#1
I did the bypass and I know somthing is not right. I was wondering if it is common for for the auto to play and not the video. Is it me are the unit?
Posted Jan 08, 2008 · 20:24 UTC#2
with the audio and no video...sounds like you have a bypass issue...
how did you bypass the unit? ground e-brake wire, move mute wire up one pin and put to ground.
Posted Jan 10, 2008 · 15:55 UTC#3
I grounded out the mute and e brake wire. I also moved the pin for the mute up one from the stock position? I am stumped!!!! I took everything out and re did it also. How many things can I ground out on one wire. I am grounding out my AVIC the mute wire, the e brake wire, and my back up camera. Is what I have happening normal and I just did the bypass wrong, or is it my unit that might have been damaged. I am referring to the auto, but no video. I have no video even when I am parked with e brake on.
