2006 Nissan Xterra VSS Wire
By Lowgear · Jan 08, 2008in Vehicle Specific Wiring💬 6 posts👁️ 2,199 views
Posted Jan 08, 2008 · 20:23 UTC#1
Can anyone tell me how to find the VSS wire on my 2006 Nissan Xtera?
I don't have the Fosgate sound system so the VSS wire is not on the radio plug. Someone told me that this car has some kind of CAMBUSS and not a speed sensor. Someone else said to remove the dash and splice into the spedo-meter. Don't know how to remove that dash!
Anyone that has wire color, info on wire location, or just some kind of logical answer please let me know.
Lowgear
Posted Jan 08, 2008 · 20:39 UTC#2
my tech info says it is lt blue in the cluster pin 6.
Posted Jan 08, 2008 · 21:13 UTC#3
Thank you. Were is the cluster located? Do I have to remove the dash? :roll:
Posted Jan 09, 2008 · 05:58 UTC#4
The cluster is the thing you stare at that shows the speed and everything. :roll:
Posted Jan 09, 2008 · 13:43 UTC#5
Well thnaks Batman for the reply. So I guess I now have to get info on getting to the cluster without ripping the whole dsh apart. If you have any info on a 2006 Nissan Xtera dash removal please send it on.
Lowgear
Posted Jan 10, 2008 · 07:30 UTC#6
Unless you have the RF stock stereo, you will not have the light blue wire at pin 6. Pin 6 will be empty. BUT, that is the location that you will run the VSS lead to.
Taking out the cluster is not a huge issue.
Here is a STEP BY STEP on how to do the bypass, as well as connect the VSS wire on your car.
http://www.clubfrontier.org/forums/showthread.php?t=19142
