Phone volume problem with BB8830
By Itsme · Jan 10, 2008in Problems/Troubleshooting💬 3 posts👁️ 851 views
Posted Jan 10, 2008 · 19:18 UTC#1
I can't seem to get the volume of the call to go up.
I have phone volume on max on the Z2, but on the 8830 it is at 1/3.
Pressing the volume up key on the 8830 yields no result
When not in BT mode (using the phone by itself) the volume key works great.
Is this a Z2 issue? a Blackberry issue? or a pairing issue?
I suspect a defective Blackberry.
Posted Feb 13, 2008 · 13:28 UTC#2
I also have the BB 8830 and see the same thing, so I do not believe that it is a BB issue. I would expect that I would also see the same behavior using a BT headset if it were an issue with the BB unit and that is not the case. I see that there is a FW upgrade for the z2 so I'm hoping that might help with this issue.
Posted Sep 11, 2008 · 18:39 UTC#3
I know this is an older thread... but has anyone figured this out yet?
I've re-paired with the volumes maxed, I've also performed the firmware upgrade... No Luck
