I read somewhere that there is an addendum to the iPod controller instructions. It said that if it is connected via the bus cable, then the power and ground don't need to be connected. Any verification on this?
Is it is true, do any of the other modules require their power and ground to be connected. It would be a much cleaner install if all you needed to connect was the bus cable.
