AVIC D3 Bypass PROBLEM
By bulletooth · Jan 11, 2008in General💬 2 posts👁️ 639 views
Posted Jan 11, 2008 · 02:24 UTC#1
Hi everybody,
I'm having an issue with the bypass. I followed proper instructions for the bypass (FOUND ON THIS SITE). I check and rechecked before installing but the screen still blanks out with a playing DVD in there while moving and I cannot do any navigation adjustments while moving either.
Any suggestions? .... Im positive the procedure was done right, I even performed continuity tests on all wires involved in procedure with a multimeter and everything checked out before sliding in the unit.
Posted Jan 11, 2008 · 03:35 UTC#2
Have you relocated the mute wire pin to the slot in the harness directly above it?
Is the relocated mute wire pin correctly and firmly seated in the harness?
Is the other end of that mute wire grounded to the car's chassis?
Is the parking brake wire grounded to the car's chassis?
If the answer to all 4 of those is yes, the bypass WILL work.
Unless there's something wrong with the unit itself or one of those wires has an internal break.
