Z2 bypass
By truckworkz · Jan 11, 2008in Hacks/Mods💬 5 posts👁️ 3,357 views
Posted Jan 11, 2008 · 18:33 UTC#1
Everything I read says Z1.
I am looking for what needs to be done to do this on a new Z2. I am assuming they have hacks for both not needing the parking brake and being able to use it while moving.
Posted Jan 11, 2008 · 19:37 UTC#2
Hack for Z2 is the same as the Z1. It's called the "two wire" bypass. I've done it personally - it works. Instructions here:
http://www.sminntech.com/z1flash.html#newbypass
Additionally, depending on your unit, the Z2 *might* need a simple software update. The CD image and instructions are located in the thread entitled AVIC-Z2 Pre/Post-June Bypass Files.
Posted Feb 03, 2008 · 22:40 UTC#3
Is the freeze update the same as the update you stating, I have done this one and would like to do the 2 wire bypass.
Posted Feb 04, 2008 · 03:59 UTC#4
I *believe* the freezing update includes the files from the bypass update (cumulative). However, I haven't read anything specifically stating that, and when I did it I used the Z2 image with came with the bypass update already applied.
So, when in doubt, do the bypass update first (if it will let you) then do the freezing update.
Posted Feb 05, 2008 · 16:10 UTC#5
freeze update contains bypass files
