btb200 not synching phonebook
By BSPX · Jan 12, 2008in Problems/Troubleshooting💬 2 posts👁️ 751 views
Posted Jan 12, 2008 · 04:53 UTC#1
I have a d3 with the btb200 and I have a verizon lg env lx9900 phone. When I go to sync my phonebook it disconnects the bluetooth from the phone (like it should) but then does nothing, I have no start option or anything, it just disconnects. I also cant find out how to manually transfer the numbers from my phone. Anyone have any ideas? Thanks in advance.
Posted Jan 12, 2008 · 05:06 UTC#2
After you press the phone book transfer and it disconnects, then go to your phone and go to your contacts. Press options and look for send name card (or something like that) and chose it and then choose bluetooth. You might have the device showing or nothing and it gives option to add device. Follow prompts to pair it up. Then go back to contacts and follow as I mentioned about the send name card. Mark the ones you want to send, press done, and it should start sending them.
This assuming that your phone is registered with the D3.
