hi guy this is my first post i'm sorry about my spell
ok i got a good one this is only to watch movies while you run first of all go to the brain unit conect a RCA WIRE from VIDEO OUT to CAMERA IN after tha hit the joystick (menu) go to SETUP then CAMERA set camera ON then set BATTERY
not GRN then return to de MAP turn you car off
so every time you start the car you view movies while you drive the only inconvenience is you going to see a prhase tha said SCREEN IMAGE MAY APPEAR REVERSED and other thing you can do is hit the AV Status then REAR VIEW button now you can view movies on one side and on the other side you watch the map
I hope this can help somebody
