04 Crown Vic police car
By Supercop29 · Jan 15, 2008in General💬 12 posts👁️ 1,625 views
Posted Jan 15, 2008 · 11:51 UTC#1
Any thing special i need to know to install Z2 in Crown Vic?
Posted Jan 20, 2008 · 09:37 UTC#2
You will have to grind off the top and bottom lips of the radio pocket to fit a double DIN radio in your CV. There isn't really any way to secure the radio in the pocket either.
Posted Jan 20, 2008 · 13:50 UTC#3
99-5805 with some minor modifications will allow you to anchor a double din in that dash.
Posted Jan 20, 2008 · 18:01 UTC#4
Got it in car last night..WOW... looks good... we just wrapped tape around it to keep it tight in hole... looks okay... works great.... haveing problems changing back ground, I think it might be my cd write on this computer, says unreadable dick when I put it in the car.
So I'm working on that.
Thanks Batman.... tell Robin hi!!
Posted Jan 21, 2008 · 04:25 UTC#5
So the avic now reads dicks eh? That's a new one. :lol:
Posted Jan 21, 2008 · 05:28 UTC#6
Is the 99-5805 intended for 1.5 DIN pockets? 03+ CV's do not have a true 2-DIN pocket
Posted Jan 22, 2008 · 02:35 UTC#7
no, it's actually meant for the ranger and older exploders. It can be modded to work, I've done it a number of times. Not a big fan of leaving a $1000+ nav system unsecured in a dash, and tape is just ghetto.
Posted Jan 22, 2008 · 07:49 UTC#8
Thanks i will see if I can find it... I also not a big fan of leaving it open!
Posted Jan 22, 2008 · 08:23 UTC#9
Tape? Tape is for Focus's.
Posted Jan 24, 2008 · 17:41 UTC#10
How did you mod it to fit? My AVIC is just sitting in my dash unsecured. I padded the sides with foam to keep it in place, but a better solution would be nice.
Posted Jan 24, 2008 · 23:57 UTC#11
After you shave down the top and bottom of the dash bezel, you'll have to take a small amount off of the top and bottom of the 2 side pieces of the dash kit. I've got one at work, if I have time I'll try and take pics of what has to be done. By the way in order to mount the avic with the kit into the car you will have to remove the dash facia from the vehicle. Then slide the kit parts into the dash opening. Finally slide the avic into the kit and remount the whole thing into the car. It helps when you go to mount the avic to the dash piece to unclip the air vents to either side of the radio opening.
Posted Feb 01, 2008 · 15:55 UTC#12
I bought it and will give it a try in a month or two when I am home again.
