Anyone done bypass wrong
By Cowboy UP · Jan 15, 2008in Problems/Troubleshooting💬 9 posts👁️ 1,468 views
Posted Jan 15, 2008 · 18:51 UTC#1
I am stuck on the bypass. I have check and re checked everything. I have moved mute wire and grounded, grounded e brake wire. Grounded ground wire. I can not get the thing to work. I have audio but no video. I can get the DVD controls to come up and they work. Just no video. I am not getting a warring light coming up saying that e brake is not hooked up correctly. I drive a 2006 Chevy Silverado. I have a backup camera hooked up as well. So has anyone had the audio but no video problem? If so, how did you fix it? I need to know if I have a bad unit, if so I need to talk to Pioneer about using my warranty. My unit was made in Aug. 2007. Please someone, give me a simple answer. I have put in about 15 cd playler, Intalled subs, disc changers. I am not great, but I have experience doing installs and I am stuck.
Posted Jan 15, 2008 · 23:19 UTC#2
You need to go after one problem at a time for starts...
Be patient!
Posted Jan 15, 2008 · 23:22 UTC#3
Many have gone wrong in the bypass. You will get no help from Pioneer in bypassing the safety...
Use the search pull down and start plugging away!
Posted Jan 16, 2008 · 01:58 UTC#4
Are you able to access all nav functions while going over 10 mph?
Posted Jan 17, 2008 · 00:02 UTC#5
I can't modify my route when driving over ten. I only have access stuff that should already work. Not the stuff after the bypass.
Posted Jan 17, 2008 · 01:25 UTC#6
Then you did the bypass wrong. Check your grounds, that the pin is in the right hole and seated firmly, etc.
Posted Jan 17, 2008 · 12:43 UTC#7
you most likely broke the tab on the pin of the mute wire, and it is not seated properly
Posted Jan 17, 2008 · 18:44 UTC#8
It looks good, but I am very willing to try and fix. How do I make it seat good, if it is not?
Posted Jan 18, 2008 · 15:53 UTC#9
1. Make sure the mute wire is seated correctly. It goes in a certain way and clicks in place so you can't just tug it out.
2. Make sure your ground wire is actually grounded.
3. Make sure the green parking brake wire and mute wire are connected to the ground wire well.
4. Make sure there are no exposed wires.
