day / night mode toggle switch
By jonster · Jan 15, 2008in Hacks/Mods💬 17 posts👁️ 6,955 views
Posted Jan 15, 2008 · 21:33 UTC#1
Because I drive with my headlights on during the day, my screen is always in night mode. Putting in a toggle switch and wiring it to the illumination wire of the AVIC would allow me to toggle between day/night mode on the D3 while leaving my headlights on all the time, correct?
Does anyone know of any pitfalls to doing this?
Thanks,
Jon
Posted Jan 15, 2008 · 22:28 UTC#2
yeah that should work
Posted Jan 16, 2008 · 03:38 UTC#3
Yep. Just wire a switch on the illumination wire. Problem solved.
Posted Feb 28, 2008 · 04:49 UTC#4
I think my illumination wire is bad. What input does the D3 need to switch between the two?
Posted Mar 02, 2008 · 20:37 UTC#5
I have the ill wire tapped into my dimmer circuit on my GMC truck. If my headlights are on the D3 goes to night mode, if I turn dimmer switch right down so no int lights, D3 goes to day mode. Give it a try.
Posted Mar 02, 2008 · 23:09 UTC#6
uhh why wouldnt you just go into the settings and change it to day time when its at night?
Posted Mar 03, 2008 · 16:46 UTC#7
I think you have that backwards. "Night mode" makes the screen darker. So turning the unit to day mode at night would yield a damn bright display at night.
I haven't had a ton of play time with the D3, but I've installed probably 60 of them. If it DOES have a day/night switching feature in the software, that would be easier IMO. If it doesn't......then use a switch. The unit looks for +12V on the illumination wire to switch into night mode. Your daytime running lights keep +12V on this wire at all times. A simple toggle switch will break the connection preventing +12V from reaching the D3. Thereby thinking you turned off your headlights. Done and done.
Posted Mar 03, 2008 · 18:23 UTC#8
Actually, the DRL's don't have any affect on the interior illumination signal that the unit is seeking. DRL's are headlights only on almost all vehicles. The signal for interior lighting comes from the headlight switch or the auto lamp control on most modern vehicles. The stock illumination wire taps into either of those.
The idea is right, though.
And yes, there is an option in the D3 to switch to daytime/nighttime all the time...but a toggle switch would be easier to throw by feel if you needed to do so while driving.
Posted Mar 03, 2008 · 19:31 UTC#9
Yeah, the toggle switch id the best way, I'd say. And since it'd be used so infrequently, I'd mount the switch up under the dash or something so it's out of sight.
Posted Mar 04, 2008 · 00:29 UTC#10
This is not the case with every car. Several installs I have done, we have to back the car out of the bay so the headlights will turn off and the D3 will switch into day mode.
Posted Mar 04, 2008 · 03:40 UTC#11
Yeah, that's b/c they've got auto lamp control and it's sensing nighttime in the bay, so it turns the headlights ON as well as dimming the interior lighting. Get it out in the sunlight and the headlights turn off and the screen will return to standard brightness.
Anyway, neither here nor there, the switch would be a quick-fix for someone that needs their headlights on during the day.
Posted Mar 08, 2008 · 17:30 UTC#12
uhh why wouldnt you just go into the settings and change it to night time when its at day?
Ok I have tryed to do that and it does not do any thing,Is my D3 bad?
Posted Mar 08, 2008 · 19:16 UTC#13
I believe that if you change the nav setting to daytime, it leaves it in daytime mode all the time. In nighttime mode, it switches (?)
If the dimming is a problem, just cut the illum. (orange/white) wire and isolate the ends. It will never dim unless you switch the setting manually.
Posted Mar 09, 2008 · 11:27 UTC#14
Would the switch be to a ground or open condition?
Posted Mar 09, 2008 · 19:17 UTC#15
Open. One side of the switch = illumination lead from D3..... the other side = +12V ignition. You flip the switch and it puts +12V on the illumination wire. It's not rocket science here people....
Posted Mar 09, 2008 · 19:38 UTC#16
OK so open it is!
Posted Aug 05, 2009 · 03:26 UTC#17
I would like to do the same thing and have a mini slide switch. Any idea what the rating for the slide switch needs to be in terms of Volts and amps?
- dan
