I have a Z-2 with ipod and xm adapters along with a Metra harness
to go along with the factory Infinity amp system in my 08 Jeep Wrangler.
The problem is that when I hit the brakes the volume drops and then
goes back to normal once I release it. Also the seat belt warning light
comes on when I apply the turn signal. I checked all the connections
and everything is fine and also I did the 2 wire bypass which works great.
I cannot see any problems with the setup. Any suggestions from you guys
would be great.These problems only started after I installed the system.
