Hey guys, I installed this unit (DMH-A4450BT) in my car less than a year ago and I have noticed that whenever I use the stereo when the car is in battery/accessory mode for too long, and then if I proceed to start the engine the unit will restart and then go into a bootloop.
However,if I don't use it in accessory mode for too long and I directly start the engine the unit never has problems, what could cause this?
My unit has a pinhole reset button so I keep a pen in my car to reset the unit whenever this happens but I have to set all my steering controls again! But doing this makes the problem go away so I can use the system in accessory mode again without worrying for a few days.
This is really annoying because sometimes I'll be sitting in my car and I have to listen to music without the engine running but I fear that the system will go into a bootloop and I have to go through the hassle of resetting again.
One more thing I observed is that even if I do let the unit run for sometime in accessory mode, but if I turn off the car completely and come back later to turn the engine on the bootloop doesn't happen, almost like the unit resets itself on its own if I leave it alone for some time.
Can someone please give me some insight on what this problem could be? Is it a problem with the motherboard or a faulty SD card like how the other pioneer units have? Or maybe a wiring issue?
