4 speakers plus subwoofer - fader works?
By Ledetent · Jan 21, 2008in General💬 4 posts👁️ 930 views
Posted Jan 21, 2008 · 01:28 UTC#1
Hello!
I'm new to the forum and have a D3 on order. I've downloaded the manuals to get a head start on how to wire it up. Have a question...
My plan is to try and wire up 2 front and 2 back speakers to D3 and use the internal amp. I have a sub that will have its own amp outside of the D3. Is it possible to wire it this way? Will fader work?
I think if I had a separate amp for the 4 speakers I could use the RCA's and everything would work.
Thanks for the help!
Jimmy
Louisiana
Posted Jan 21, 2008 · 02:15 UTC#2
Yep, you will be fine
Posted Jan 21, 2008 · 09:22 UTC#3
You can control balance and fade normally, sub woofer output is on a completely different menu.
Posted Jan 23, 2008 · 01:05 UTC#4
The sub is non-fading. Meaning if you fade to either the front or back interior speakers, the sub will still play. You will have to actually turn the subwoofer output off from the sub menu in order for it to not play while fading.
