I wired up my backup camera today, finally, and it doesnt work. I cant find my installation manual for my D3 so that probably has a lot to do with it.
Heres what I did: camera is mounted on the back bumper, power to camera is hooked up to the 12v wire thats hot when backup lights are on (so it gets power only when im in reverse), camera is grounded to frame, video cable is ran up to the unit and plugged into "rear camera input", and the purple wire for +12v reverse gear signal is hooked up to a wire that I know gets 12v when I put it in reverse. I tested everything and I dont know why it isnt working.
I know the camera works cause I hooked it up to a 12v battery and plugged the video into the TV in my living room...
Am I supposed to have power going to the camera at all times with ignition on?
Is there another wire coming out of the unit I need to hook up?
It doesnt switch to rear camera view when I put it in reverse, and I cant go to "rear view" mode in the menu in nav mode-
What the hell is going on???
