Rear Camera Problem
By Adennick · Jan 26, 2008in Problems/Troubleshooting💬 17 posts👁️ 3,264 views
Posted Jan 26, 2008 · 01:39 UTC#1
I installed one of those $40 eBay lipstick cameras on my truck. I have a Z2.
My problem is that the camera will not show any picture on the rear-camer input (brown RCA plug on radio harness). It just shows a black screen. Occasionally, it will flicker a few lines, but no picture. It shows a perfect picture when plugged into the AUX input.
Posted Jan 26, 2008 · 18:45 UTC#2
a few of us have had bad reverse camera inputs and had to send them back for service.
Posted Jan 28, 2008 · 19:29 UTC#3
i didn't know there was a common problem. I've had problems with my camera output looking much crappier than when i first got it. it's one of those license plate cams, so i don't know if its the unit or the cam.
Posted Jan 29, 2008 · 15:16 UTC#4
Could this just be the harness? Or were your problems internal? How do I get it fixed?
Posted Jan 29, 2008 · 22:04 UTC#5
the problem was internal send it back for repair
Posted Jan 29, 2008 · 22:42 UTC#6
Isn't there an option to change the polarity of the camera? I think it's on the screen where you tell it whether or not you want the back-up cam ports active. Just a thought.
Posted Jan 31, 2008 · 03:44 UTC#7
we had that problem with two units (Z2's), but then finally realized it couldn't be two bad units!!
long story short...........
i found the problem to be with the harness. check the wiring at the white plug that has the brown rca (camera input) the ground (shield) pin wasn't in all the way.
hope this helps....
Posted Jun 20, 2008 · 00:07 UTC#8
hope this helps....
Same thing happend in 2 units?
Posted Jun 24, 2008 · 03:52 UTC#9
IS THERE A WAY TO ADJUST THE LIGHTING ON THE REAR VIEW CAMERA. IT IS A LITTLE DARK. I HAVE A z3 UNIT.
Posted Jun 26, 2008 · 15:09 UTC#10
I am having issues with the rear view as well. I have it also signal split to a rear view mirror and the image is perfect on there. I've switched out cables, check this and that, thinking it is still the harness from the unit itself. Any other suggestions besides sending it back for service?
Posted Jul 03, 2008 · 14:25 UTC#11
Thanks for the response on the camera. The dealers states that this the best this camera can do. If we want a better lighting we would have to buy a more expenssive camera.
Posted Jul 05, 2008 · 01:23 UTC#12
mine flickers a few lines every once in a while but mostly a blank screen with the words "image may be reversed"across the top.when you all say send it back for service,are you sending it back to pioneer?how long does it take to get it back?
Posted Jul 12, 2008 · 03:26 UTC#13
My unit now has just started to not to display..
It will work and then not.. If it works it will until I turn off the car..
Damn, it just started today..
Look into it tomorrow
Old
Posted Jul 12, 2008 · 03:40 UTC#14
I took the car back to Hi-Fi for other problems and they also adjusted the camera. It now works very well.
Posted Jul 13, 2008 · 17:27 UTC#15
I have no idea unless it was very hot that day (has been for a few weeks near 100 outside)
It has worked for a few days now with no problems..
Do the Z series have issues with heat (Z2 is my unit)
Old
Posted Aug 03, 2008 · 03:54 UTC#16
My backup camera started turning off sporadically for a few seconds. Usually it's on a lot longer without turning off if I am not driving. I thought it maybe loose wiring and it happens mostly when I drive but I drove on bumpy roads and it's still fine but it will turn off for a second or two every once in a while. Could it be heat (asking same question as old? It's hitting over 110 here. I have a JVC KV-CM1 (btw any input about the quality of this camera?)
I checked the power in the Z3 under Settings-Hardware-Connection Status- Power and I see the power changing anywhere between 13.4 to 14 VDC. Could the power be causing the camera chipset to shut-off to prevent burning? I may be completely wrong - just guessing. Any suggestion is greatly appreciated.
vegas
Posted Aug 08, 2008 · 21:52 UTC#17
My rearview (Z2) is on when in drive, and park, but not in reverse. Also works in the "rear view" mode. Also the CD quit working. Will update when I get it back from installers.
Worked fine for a year or more.
