Hi everybody,
I've been reading up on my problem and exhausted every option on the threads, so i've done my homework, but i need help..!!
So i have a 2005 GMC Sierra 2500HD Duramax, i've had my D3 installed for 3 weeks now and everything works great except for the vehicle speed under the vehicle dynamics. the message says "this feature is not available now." and the distance bar on the 3-D calibration has no bars. i've reset the unit and still nothing. the sensor is in "sensor initializing" mode and has been that way since i've installed the unit.
I have my VSS wire to what i believe is hooked up correctly. I have done numerous diag's on it, under the hardware i've looked at the pulse and it does go up as i drive and beeps, readings will go up past 50 pulses.. so i'm not sure if that is normal.
i tapped into the yellow/black wire in the PCM. i was thinking about re-checking the connections etc., but before i pull everything apart again i just want to get any opinions.
AND... is it necessary for the VSS wire to be connected in order to have the speed and distance reading to work? because i know that this option usually works off of the GPS antenna, similar to any TOM TOM or similar. That speed is from GPS, not the vehicle.
Please let me know what it could be.. i appreciate any help i could get. i've contacted pioneer (they know nothing BTW) no help what so ever.. they basically hung up on me.. i was actually telling them what to do LOL..
