Avic D3 in the Lincoln LS
By svince1884 · Jan 28, 2008in Hacks/Mods💬 3 posts👁️ 1,368 views
Posted Jan 28, 2008 · 01:02 UTC#1
I've got a 2002 Lincoln LS nonsport. I tried doing the bypass...I pulled the mute wire (yellow/black wire) out, then put it into the slot right above it's original location. Then I used a wire tap to run the mute wire to another tap that had the parking brake wire(green wire) and the ground wire coming from the Avic. I grounded the wires and it still doesn't work. When I start my car I always get a message that says:
Caution: the system has detected a problem with the connection of the parking brake lead....blah blah blah....
I can watch movies as long as I go under 10. Seriously anybody got any suggestions?
Posted Jan 28, 2008 · 04:49 UTC#2
Wrong forum number one. Number 2 there's 3 stickies on how to do it. Read them. Every possible problem with the bypass has been discussed.
Posted Jan 28, 2008 · 18:14 UTC#3
Its the lower slot. It was already bypassed.
