Update. Spent 2 hours driving around today trying to figure out what might have triggered the "glitch" where I can't load a CD.
If I try and load a CD right after start up, it will load.
If I try and load a CD after driving around for a few minutes, It won't acccept a CD.
I tried only using the FM first.. Same result.
I tried setting the CD to manual rip - Same result.
I tried using all the other AV functions first, then trying to insert a CD - Same result..
The screen will slide down, but it won't allow me to insert a CD- UNLESS I TURN OFF THE IGNITION AND RESTART AGAIN.
I called Pioneer Tech hoping they would tell me - We've had this problem before, and this is how to fix it..
Didn't happen, the guy told me to do the following: push the reset button - which would be the 4th time I've tried that. It works for about half a day, then it won't accept CD's again..
He next told me to delete my entire hard drive - I asked him if the instructions are in the owners manual, as I couldn't do it right then, and he said yes they are - Use Method 3. Looked in my owners manual, couldn't find any instructions, much less a method 3. Are those instructions in the owners manual and I missed them?
I personallly don't think any of this is going to fix my Z2. I called the installing dealer, and he told me to try whatever tips tech support told me to try, and he would try and help me as much as possible, but I realize that when I had the installer do the bypass - it would void the Pioneer warranty.
Since about 75 percent of Nav systems get the bypass, whether they be original equip and bypassed later, or systems like the Avic-Z2 added on - what happens if there is a problem like mine... I paid $2,500 bucks to have the Avic-Z2 installed and bypassed, with the Bluetooth, and a license plate back up camera..
I purchased it and had it installed - ONE MONTH AGO!!!
If the Pioneer warranty is voided by doing the bypass - and there is a problem with the unit that doesn't seem to have anything to do with the bypass - what are my options???
Thanks guys... Bob
