Address not found problem N2
By Musketeer · Jan 29, 2008in Problems/Troubleshooting💬 4 posts👁️ 916 views
Posted Jan 29, 2008 · 01:19 UTC#1
Hey Guys
My N2 just started going goofy on me, when I put in any address, the unit says "address not found, do you want to continue?" I hit yes and it says "route failed" and it won't navigate. The POI's work fine, anybody know the problem here?
:shock:
Posted Jan 29, 2008 · 23:54 UTC#2
Do you have it set to the correct zone?
Posted Jan 30, 2008 · 02:56 UTC#3
yes, it finds all of the POIs in the area, so I did a test...
I POI'd my closest McDonalds and copied the address, I then backed out and put in the address, the unit said, (address not found, continue?) and then said Navigation failed.
I can go there through POI but not through the address, any ideas?
Posted Mar 20, 2008 · 06:21 UTC#4
I'm having the same problem, does anyone have a solution to this?
