Draining truck battery - bad installation?
By KRanch 05' F250 · Jan 29, 2008in Problems/Troubleshooting💬 4 posts👁️ 836 views
Posted Jan 29, 2008 · 20:44 UTC#1
I recently hooked up the AVIC Z2 and also the ipod interface about two weeks ago. Recently I have been experiencing problems with my car battery going dead. When I jump start the battery seems to be charging, however, the battery is dead the next morning. Is it possible that I screwed up the installation? Thanks.
Posted Jan 29, 2008 · 20:56 UTC#2
It could just be that the battery has a bad cell; I would suggest that you get the battery checked out at your local Auto zone or somewhere. I don't see how the unit would be drawing the power down if it powers down when you turn the key to the off position. .....The unit does turn off I presume? As long as power drops from the ACC (Red) wire when the ignition is off, that should kill the unit and the fan.
Posted Jan 29, 2008 · 22:01 UTC#3
Thanks. I'll check the battery.
Posted Jan 30, 2008 · 17:33 UTC#4
Do you have an ipod in the car?
