Voice command is not working.
By Passat 05 · Jul 30, 2006in Problems/Troubleshooting💬 22 posts👁️ 4,643 views
Posted Jul 30, 2006 · 02:41 UTC#1
Installed my Z1 and everything is working great except for the voice command. The mic must be plugged in correctly because it gives me the Voice command icon. Touching it brings up the initial message but no matter which voice command I try it brings up the X-icon and then askes me to touch the voice command button (again). I've talked lauder, slower, closer to the mic.....nothing.
Any ideas anyone?
Posted Jul 30, 2006 · 16:18 UTC#2
My guess the mic isn't actually plugged in. I don't think the Z1 has any logic to detect the mic being plugged in as to whether it shows you the voice command icon or not, as far as I can tell it's always there.
I had my mic come unplugged a couple of times with the hassle of stuffing so many wires into such a cramped space in my dash. It would have been nice if pioneer had mad a connector that would clip in on the Z1 like the other connections.
I'd bet it's the mic connection itself. It sucks having to pull the deck back out of any install, but that's where my money would be given the description of your problem.
Ralph
Posted Jul 30, 2006 · 17:56 UTC#3
I am not even getting the Voice Command Icon on any screen. What do you think is my problem?
Posted Jul 30, 2006 · 18:16 UTC#4
Actually it does, if there is no mic, there is no icon on the screen.
And maybe since "passat 05" is from Toronto the Z1 can't understand the commands with "eh?" tacked on to the end of each one. :)
Posted Jul 31, 2006 · 00:13 UTC#5
Aaaahhh, you mean I shouldn't say "Destination eh"? :?
Actually it turned out to be a bum Mic.
I plugged in my earpiece from the cellphone and it works as good as any mic. Then checked the mic cable and found a soft spot in the cable. Turned out to be a break in the inner corewire. Soldered it back together and I expect this mic to be working when I get back out there.
Interesting though how well that earpiece works as a mic. :D
Posted Jul 31, 2006 · 00:23 UTC#6
Yah, sorry my lame attmpt at humor. I just find Bob and Doug very funny. :) Hope I didn't offend.
Wow, that stinks, I would have never thought to check the wire. It's pretty cool that your headset works as a mic, if you have the bluetooth setup have your called listen for an echo. Most of us think the stock mic kind of sucks. If you have a decent working substitute, that might be something some of us would like to try.
Posted Jul 31, 2006 · 01:21 UTC#7
Yep the mic is working now and Ducatiboy, I can now confirm that Navi-Heidi actually does understand Canadian. "Destination eh" works just as good as "Destination". .....That's a relieve, at least now I don't have to learn myself US.
Offended?? Never!! :D :lol:
Posted Jul 31, 2006 · 01:30 UTC#8
Don't have the bluetooth yet but can confirm that other mics will work just fine with 'voice command'. :idea:
Posted Jul 31, 2006 · 01:35 UTC#9
Well tell us what you plugged in there which works, I'm sure someone here with bluetooth is dying to try another mic.
Posted Jul 31, 2006 · 08:55 UTC#10
Since I have no Voice Icon at all and have never seen it once since installation you guys think that the mic was never plugged in?
Quite possible that they guy ran the wire and either forgot to plug it in or it came out when putting the Z1 into the dash.
I should find out when my Bluetooth comes in this week. Where should the bluetooth be installed to get a good signal from the cell phone? Any pointers greatly appreciated. Thanks.
Posted Jul 31, 2006 · 11:14 UTC#11
Yep, it's not plugged in. Otherwise you would have the icon, it's not smart enough to actually sense the mic, my guess is that it's the "sense" that there is a plug in the back, if the wire is cut before the mic, it would still show you the icon.
It could be, that's exactly what I did. :)
It doesn't really matter, mine is behind the dash. It comes with 3 feet of wire so you can put it somewhere other than right behind the Z1. You might not want to run it further away from you, where depends on the vehicle, but you might want to just run it to under the steering wheel or somewhere close to where you might store your phone (in you pocket or in the center console).
Posted Jul 31, 2006 · 12:42 UTC#12
Just a $5 no-name earpiece.
I was not able to tell a difference between this and the Pioneer mic.
Both work the same close up and at arm length, eh. :lol:
Posted Aug 01, 2006 · 16:00 UTC#13
Either that or he plugged it into the external speaker port instead of the mic port...
Posted Aug 01, 2006 · 16:18 UTC#14
I was thinking thats what he may have done also.
Thanks. I got my bluetooth delivered today from crutchfield so I'm going to take a look.
Posted Aug 12, 2006 · 18:02 UTC#15
Is it true that you can either have the steering wheel hand controls OR the Voice Command but not both???
Additionally, there was no MIC in my Z1 box and I did the install and layed everything out before I completed the install. No MIC present :(
~WW999
Posted Aug 13, 2006 · 14:34 UTC#16
No...you can have both.
Posted Aug 13, 2006 · 23:06 UTC#17
I dont see why you wouldnt have gotten a mic on your Z1 box. I would call Pioneer and let them know and they should send one out to you. Look in your instructions and it should tell you everything that was supposed to be in the box.
Posted Aug 16, 2006 · 04:26 UTC#18
you guys bring up a good point!
we may be able to use higher quality mic to eliminate the echo'ing!
has anyone tried this?
Posted Jan 02, 2007 · 19:51 UTC#19
I have the same exact problem as the original poster... I have the icon, I then press the voice button on the remote, and it waits for a command, I tell it a command, and then after a second or two it gets the red X and stays that way until I press voice again. So, it has to recognize the mic or it wouldn go through those paces. Any ideas? Ive spoke louder and quiter, softer etc...
Posted Jan 02, 2007 · 19:56 UTC#20
first, the echo canceling is typically software geared. within reason and you dont have some hooky mic, thats why the update for the bluetooth has seemed to work for many. its software.
as for the unit not recognizing voice commands. Make sure that when you press for voice command, you say one of the on screen commands that it looks for. dont start rattling off other words. speak clearly, and for testing purposes, towards the mic, you dont have to inhale the thing but maybe direct it towards it and see what happens
Posted Jan 02, 2007 · 22:27 UTC#21
Someone else a while back had this problem and no command was recognized and what happened was that the wire inside the insulation was broken and even though the Z1 sensed the plug in the back of the unit, the wire was broken going to the mic and it wasn't picking up any sounds.
I'm not saying it's your problem, first I would follow tillithz's ideas, that's a good starting off point for testing. Also for testing, make sure your vehicle is off and not moving, just to get out the noise issue. Mine doesn't understand me if my windows are open.
If you put it in (or can get to the back of the unit), make sure the plug is all the way in.
Posted Jan 02, 2007 · 23:52 UTC#22
spliced wire, thats nice to know that it 'COULD' be that. note for the future.
