Got my AVIC-D3 installed today (by myself). Everything works great, except the BOYO backup camera (VT400).
If I don't actually connect the camera, the D3 switches into rear-view mode when I put the vehicle in reverse. I have verified that I get 12V in reverse, and 0V otherwise.
If I connect the camera, the D3 doesn't even switch into rear-view mode. It does absolutely nothing. I put a voltmeter on the white plug where the camera connects, and I get 12V when in reverse and 0V otherwise. So I'm getting voltage to the camera, but for some reason the D3 doesn't want to switch over.
I'm really hoping I didn't mess up the cable, but I was pretty careful with it. It took me 2 hours to run it through my Ridgeline, so I really don't want to pull it out again.
What are the odds that it's the camera itself that's bad? Anyone else ever seen this with the D3? I have the rear-view camera enabled, and set for positive voltage to trigger. I tried negative, but it does nothing. Besides, without the camera connected the D3 does switch into rear-view mode.
