I've read them all, I know what to check but I'm doing something wrong.
I removed the cellphone mute wire by lifting up the tang and inserted it into connector 2, lowest right hole I then simply spliced the green parking brake wire into the mute wire and grounded the mute wire to my dash. I put everything together and drove the truck around the block and it stopped working. So I figured I'd messed up connector 2 somehow, I slightly tugged on it and it moved slightly so I put a dab of super glue but no dice, it still gives me a warning that my parking brake wire isn't hooked up correctly and locks me out. BUT in the connection status it says parking brake is engaged?! I've searched and searched but no one seems to have this problem, what should I try next? Do you think it could be because I spliced the parking brake and mute wire together?
Or should I run the update? I already burned the CD and tried but when I insert it and press the 'map' button I have no option to update my Z2
I forgot to add, thanks to everyones help my z2 performs flawlessly except for this! So thanks for everything!
