no voice guidance
By 06 Envoy · Feb 04, 2008in Problems/Troubleshooting💬 9 posts👁️ 1,429 views
Posted Feb 04, 2008 · 02:53 UTC#1
I can't get my voice guidance to work. The beeps work fine. I have reset the unit. My current setup is avic d3 with gm os adapter to bose amp. The music plays fine. I have set it to max volume guidance on and mute in the main initial settings. What am i doing wrong? UGHH!!! :twisted::?:shock:
Posted Feb 04, 2008 · 02:55 UTC#2
on ya i forgot its in an 06 envoy with factory bose
Posted Feb 04, 2008 · 04:19 UTC#3
Dous the audio mute as if it were going to give a voice prompt, but the voice never happens? The guidance voice only comes out of the front speaker outputs. I read somewhere that the bose system only accepts a 2 channel input and then splits it internally to the 4 speakers, IIRC. The rear output from the D3 is probably hooked to the bose amp, which doesn't carry the voice prompts. Try connecting the front outputs to it instead.
Posted Feb 04, 2008 · 07:23 UTC#4
Try this I dont know if it will work for your car but it fixed my problem.
The factory amplifier accepts two channel audio only. The
amplifier fading is controlled by data communication from the factory radio. Therefore the aftermarket radio will not have the
capability to control the amplifier. Please connect the Front outputs of the aftermarket radio to the Rear inputs of the 22 pin
connector. This will allow the Navigation unit voice prompts to be heard. The rear speaker outputs of the radio are not used.
The factory amplifi er Balance and Fader is set to center by the interface.
Posted Feb 04, 2008 · 21:02 UTC#5
the mute never happens i'm running it through the front outputs i can hear the beeps fine but it never mutes or has voice
Posted Feb 04, 2008 · 21:02 UTC#6
the bose is a 4 channel amp
Posted Feb 04, 2008 · 21:07 UTC#7
its running out of the avic to the adapter which has 4 channel inputs
Posted Feb 05, 2008 · 02:57 UTC#8
We just installed my girlfriend's D3 on her Eclipse Spyder as well and we have the same problems. The voice guidance setting is turned on and it just beeps with no voice guidance. I have a D2 on my Eclipse and we wired the setup very similar and mine works perfect.
Posted Feb 06, 2008 · 01:03 UTC#9
the bluetooth unit will mute the radio on incoming phone call that all works fine so i am clueless
