VSS on 03 Eclipse Spyder??
By djkms · Feb 04, 2008in Vehicle Specific Wiring💬 7 posts👁️ 1,313 views
Posted Feb 04, 2008 · 19:22 UTC#1
So I have conflicting places to find the vss wire for my vehicle. One place says some wire near my tranny. Another place says use the wire behind the speedometer. Yet another place says behind the center console. Where is the easiest place to find this elusive VSS wire. I would prefer not to go through the firewall if I dont have to.
Thanks for your help!
Posted Feb 05, 2008 · 01:17 UTC#2
Speed Sense WHITE/BLUE ECM BEHIND GLOVEBOX
Posted Feb 05, 2008 · 01:36 UTC#3
Now its behind the glovebox, this just gets better and better! :D
Posted Feb 05, 2008 · 17:31 UTC#4
That is the right location for it if the car is a manual tranny. PIN 86
DJKMS be more specific so I can get the right wire, Manual ? AUTO? GT? GTS? GS? spider with sportronic or without?
Posted Feb 05, 2008 · 19:25 UTC#5
2003 mits eclipse spyder GTS 5 sp manual trans..
thanks
Posted Feb 07, 2008 · 20:05 UTC#6
White/Blue at ecm pin 86 it is :D
Posted Feb 07, 2008 · 22:36 UTC#7
OK this is for anyone else that might need more info for this vss wire. The ECM is located behind the glovebox. You dont need to remove the glovebox to access the ecm. Stick your head underneath the glovebox, remove the vent, it pulls out and viola, theres your ECM. I attached the wiring diagram so you know exactly what wire it is.
Thanks for all your help guys!
30-1312_connection_diagram.pdf
