D3 Whines
By RidinaZ · Feb 05, 2008in Problems/Troubleshooting💬 11 posts👁️ 1,398 views
Posted Feb 05, 2008 · 20:39 UTC#1
i installed a d3 in my 2003 350z along w/ an amp and front speakers.
It was working fine for a couple days until i decided to move the amp.
now when the car is on and accelerates it makes a horrible whine noise, very unpleasent.
I checked my grounds on the amp( i ended up not moving it and reconnecting all the wires) and it was fine.
I get no whine when the d3 is not connected to the amp.
any help?
im thinking and dreading that i blew the rca fuse but id like to hear input before i contact pioneer.
Posted Feb 05, 2008 · 23:10 UTC#2
Try grounding the RCAs.
Posted Feb 05, 2008 · 23:20 UTC#3
okay can you explain to me how to do this?
thanks for the reply
Posted Feb 05, 2008 · 23:22 UTC#4
Run a wire. Shielding of the RCAs on one end, Ground the other end
Posted Feb 05, 2008 · 23:25 UTC#5
okay thanks i will try that
Posted Feb 05, 2008 · 23:42 UTC#6
I still dont understand that. is there a diagram or a picture i can see to understand. Im having the same issue.
Posted Feb 06, 2008 · 03:47 UTC#7
Wrap one end of a bare wire around the metal part of the connectors at the head unit end of the RCA cable. Ground the other end of the wire.
Posted Feb 08, 2008 · 02:17 UTC#8
Thanks Im gonna try it.
Posted Feb 09, 2008 · 20:03 UTC#9
thanks whtcrxghst,
i got it to work today by grounding the av wire to my ground point.
I guess i must have blown the rca fuse, but its great that i dont have to replace the unit.
thanks for the help
Posted Feb 09, 2008 · 22:34 UTC#10
:wink:
Posted Feb 14, 2008 · 05:29 UTC#11
Wow, a ground loop in a car? That's crazy, I wonder where the source is. He could have also used a ground loop isolator but I'm not sure how much one for 2 RCA's would go for.
B-Far
