Bluetooth problem with Z2, I'm frustrated!!!
By Agro · Feb 06, 2008in General💬 8 posts👁️ 1,533 views
Posted Feb 06, 2008 · 06:42 UTC#1
I posted this before with no response from anyone.
Here's the problem:
I paired my BB Pearl 8100 w/ my Z2 a while ago. I have since bought a BT headset and don't want to use my Z2 (and I don't feel like taking it apart to disconnect the BT module). I removed the "AVIC Z2 HDD NAV" device from my phone's BT menu. When I make calls I get prompted on my Blackberry "Please enter the password for AVIC Z2 HDD NAV" and it causes my calls to crackle.
How the hell can I stop the Z2 from trying to pair with my phone?
I held down the reset button and turned my car on. It cleared out stuff like my brightness and such. Still It prompts me.
Posted Feb 06, 2008 · 06:50 UTC#2
[EDIT]
Removed my completely irrelevant post to minimize confusion ;)
Posted Feb 06, 2008 · 06:52 UTC#3
Yes I removed it. If I go to the Pearl menu, it only shows the Motorola headset. I tried re-pairing (which worked), then removing. Same problem arises.
So maybe I should download the latest BB Handheld software and just blow my BB away clean. It's synchronized on our Blackberry Enterprise Server, so I won't lose much really... If I still get this issue afterwards, well damn. Hmm... I'll try it tomorrow and let yall know.
Posted Feb 06, 2008 · 07:03 UTC#4
Ah, I completely read the first topic wrong! :lol: I thought you said you cleared it from the Z2!
Okay, there is no one-off way to remove paired phones from the Z2. You can either pair 5 other phones (the rest will drop off as only 5 can be paired at a time), but since that probably isn't practical, the other way is a Level 3 reset of the Z2.
For more info on resetting, check Pg 179 - 182 in the Z2 manual.
Basically,
  • [*:gbny319f]Turn the ignition switch off.[*:gbny319f]Press the RESET button.[*:gbny319f]Start the engine.[*:gbny319f]Touch and hold the MAP button while the start-up screen is displayed.[*:gbny319f]“Clear memory†screen appears.[*:gbny319f]Touch [Reset].[*:gbny319f]Touch [Yes].
The setting values stored in the hard disk drive return to the default or factory settings. After that, the navigation splash screen appears.
Good luck!
Posted Feb 06, 2008 · 07:31 UTC#5
Ok.. makes sense.
Yeah the 5 device thing didn't seem to fly too well. I changed my phone name from "AgroPhone" to "AgroPhone2" and yet it still prompted me for the Z2 pass on my phone, like it was paired to it or something, even though it was deleted.
I will try this tomorrow when I start my car before work. If that doesn't fix it, I'll try the BB re-load. Results to come.
Posted Feb 07, 2008 · 11:28 UTC#6
Please see my post...
http://www.avic411.com/forum/viewtopic.php?t=12690
I'm having exactly the same problems, plus some others with the same phone. It's not the phone as it works fine with 3 other BT headsets. It's obviously something with the Z2 BT-ND1. I'm interested to hear if anyone finds a fix. I can't even find that there are any adjustments on the BT, except for the volume through the car audio system.
Posted Feb 07, 2008 · 16:39 UTC#7
After I did that reset as stated before by another, it cleared it up. I didn't do the restore to factory defaults, but just reset. I kept all my custom POI and such, but lost all my other settings. No longer does the Z2 attempt to pair with my phone anymore.
Posted Feb 07, 2008 · 17:32 UTC#8
Awesome! Glad to hear you're up and running. :)
