OK i have done the mod to my D3 and every time i get done with it works like a champ when test it. but then later when i go to utilize the hack whether it be play a movie while driving or use all of the features of the GPS or blue tooth it's like the hack isn't working. I did have the VSS and the parking brake grounded too the same bolt and the mute wire grounded t the black ground wire on the side of the head unit. so i have moved the vss wire to my vss from behind my gauges. and i was hoping to hook the mod up to a led switch so I was wondering how you configure it for the three prong which is supply volts/on acc/grnd? not sure since i a trying to send a ground signal to the head unit? if it works will i still get the improper brake connection prompt when i turn the unit on?
MULE
