No sound.......btb200
By qbinican · Feb 07, 2008in Problems/Troubleshooting💬 5 posts👁️ 1,182 views
Posted Feb 07, 2008 · 15:48 UTC#1
I just bought the blackberry pearl and after a few failures I was able to connect it with the D3, transfer my address book and auto connect. But there is one problem, I am not getting any sound The phone rings through the speakers fine but when I answer I can't hear the person. Not sure if the person can hear me since I forgot to ask. I left the manual in the car but is there a volume control that is set off? Any help would be appreciated
thanks
Posted Feb 07, 2008 · 17:38 UTC#2
My initial reaction is to check your IP bus cabling as it's usually the cause for silence from IP-Bus devices that otherwise seem to be working.
But then you said you can hear the phone ring... hum... Check anyway? Make sure Blue is connected to blue, and black to black. I gotta admit, when I first pur everything together, I misunderstood the labels and plugged mine in backwards like many others on the forum have.
Posted Feb 07, 2008 · 17:57 UTC#3
I know I connected it right, blk/blk and blue/blue but I will check to see if its lose. I am hoping it some thing simple like that :) Thanks for your response :)
Posted Feb 13, 2008 · 20:51 UTC#4
its the phone i always have problems paring black berry windows based phone is why.buy a parrot or wait cause pioneer is suppose to be fixing the problem and will be using parrot software
Posted Feb 13, 2008 · 20:55 UTC#5
Got it working, the wire was loose from the HU. The pearl works great!!!!
