Avic D3 - sound just..stopped
By golden · Feb 10, 2008in Problems/Troubleshooting💬 5 posts👁️ 806 views
Posted Feb 10, 2008 · 04:47 UTC#1
Hi Guys,
I had the Avic D3 installed in my 98 prelude, and everything was fine. After double checking everything, I ran through the nav / dvd / cd one last time. I put everything in its place, and began screwing everything in. After the third or so screw, the sound just kind of farted out and slowly faded to nothing.
I've turned the car on and off a few times, reset the Avic, and have no idea where the sound went. The cds play, the dvds play, everything plays - just no sound. I'm assuming it's a wire or something, but which wire controls ALL the sound?
Posted Feb 10, 2008 · 10:19 UTC#2
Sounds like you wired something wrong?
Do you know what you are doing when it comes to installation?
Posted Feb 10, 2008 · 11:07 UTC#3
Thanks for the reply!
Yep, I've wired many decks before. Normally I would understand that something was my fault if it had no sound to begin with, but it lost sound right in the middle of a cd - after being on for 10 or so minutes.
Like I said, I was screwing it in at the time, and it's very likely that something got bumped. Again, I'm not sure what it would be - anyone have any ideas as to what one thing could just cause a complete lack of sound from all speakers, but change nothing else?
Also, this car has no other amps - it's just the D3 into the wiring harness.
Posted Feb 10, 2008 · 20:41 UTC#4
I would double check that the speaker wires are terminated correctly and not shorting out on each other. Also check that the mute wire is not grounding out on anything
Posted Feb 11, 2008 · 11:39 UTC#5
problem solved! If anyone has this same problem, try your factory wiring harness - I had to bend mine until a loose wire found its way in place - now everything's perfect!
