Can someone tell me the locations of the VSS wire on the 1996 BMW 740 IL?
HELP!! VSS Wire 96 BMW 7 Series
http://www.the12volt.com/installbay/ala ... /2367.html
Read that link. It lists the "Tach" wire but Im not sure if that is the same thing as the Speedo wire. the site I linked to is a good resource, I found my VSS info on there bc I was freaking out that I couldnt find it. Keep searching on that site. FYI, a very simple google search brought that up so keep looking on google then come back here if you truly cant find it.
http://www.the12volt.com/installbay/alarmdetail/2367.html
I have done a tone of googling really havent found any info on what im looking for. not atleast for my year , make of car.
Tach is NOT the same as speed sense. Here's what I have listed for a 96 7series
White AT TRANSMISSION CONTROL MODULE ON PASSENGER SIDE UNDER HOOD
so your saying the white wire is the vss wire i need and what about the revers wire?
I don't have a listing for the reverse wire.
ok what does this TRANSMISSION CONTROL MODULE look like and are the wires exposed? how do exactly find it and do you have any pictures?
Dunno
probably not
and no.
okay thanks for your help, but i would hope there is a easier and better way to hook this thing up. i dont need to mess anything up. would cost me a fortune to fix
