Finished Install but have a couple problems
By taytaythatsme04 · Feb 14, 2008in Problems/Troubleshooting💬 20 posts👁️ 2,708 views
Posted Feb 14, 2008 · 08:01 UTC#1
Well I finished my D3 install on my 350z, and my rear view BOYO camera is not working. The camera will not view when the car is put into reverse.
Also my amp to my sub is not turning on.
Any ideas??
T
Posted Feb 14, 2008 · 11:55 UTC#2
camera must be enabled in the setup menu.
Posted Feb 14, 2008 · 13:05 UTC#3
it is.
T
Posted Feb 14, 2008 · 19:46 UTC#4
Did you hook up the reverse wire correctly?
Posted Feb 14, 2008 · 20:00 UTC#5
Did you get the amp's turn on signal from the D3's blue wire or blue/white wire? Because one is made to be a system turn on for amps and the like, which is powered on all the time, and one is made for powering an antenna motor or booster, so it is only on when the D3 is using the AM/FM tuner as the current source.
Does the amp power on only when using the AM/FM tuner, or not at all?
If the amp does power on while in tuner mode, but not with any other source, that's what your problem is. To fix it easily (instead of going behind the dash to switch the power antenna wire to the system remote wire), just go into the settings menu and change the auto antenna setting from RADIO to POWER and the power antenna wire will operate exactly like the system remote wire:
Posted Feb 15, 2008 · 01:42 UTC#6
I have the amp connected to the "amp turn on" wire, and the antenna is also connected to the correct blue wire.
I get no power to the amp when I switch between tuner mode or any other mode.
Posted Feb 15, 2008 · 02:17 UTC#7
Run a jumper wire from the positive wire on the amp to the remote turn on input on the amp. If the amp turns on that way, either the turn on wire from the D3 is disconnected/broken somewhere, or the D3 isn't sending out power on the remote output. If it doesn't turn on, then there is a blown fuse on either the power wire or the amp, the amp's ground or power wire is bad, or the amp is dead.
Posted Feb 15, 2008 · 02:49 UTC#8
I try that when I work on the car tomorrow after the rain stops.
Any ideas on the BOYO camera??
T
Posted Feb 15, 2008 · 02:55 UTC#9
Did you hook up the reverse wire correctly? Does it work when you select rear view as the navigation view mode?
T
Posted Feb 15, 2008 · 03:05 UTC#10
T
It wont switch when in reverse and isnt even selectable in the AV source menu.
T
Posted Feb 15, 2008 · 05:42 UTC#11
Go into the connection status screen. Does it go from low to high when you put the car into reverse. If it doesn't then you've got a bad connection to the reverse wire or you have the wrong wire.
Posted Feb 15, 2008 · 08:06 UTC#12
Even if the connection is bad I should still be able to view the camera through the AV sources correct??
T
Posted Feb 15, 2008 · 13:05 UTC#13
no the backup camera doesn't come up asa a source. You have to go to the map, then you can change the map display to show as split screen of the nav map and the backup camera input.
Posted Feb 15, 2008 · 18:36 UTC#14
I didn't know that, I try that also.
I'm still reading the rather large manual.
T
Posted Feb 17, 2008 · 02:00 UTC#15
Ok I checked that and I get low no matter if the car is in reverse or not. So I guess my reverse wire is wrong
But I got my amp to power.
T
Posted Feb 17, 2008 · 03:55 UTC#16
ok now I got the right signal wire but the camera is all black when brought up on the screen....
any ideas??
T
Posted Feb 17, 2008 · 06:41 UTC#17
Is the camera's video output hooked to the correct input? It's the brown RCA connector on the D3.
Posted Feb 17, 2008 · 07:27 UTC#18
yes, the one labeled "Rear View Camera Input"
T
Posted Feb 21, 2008 · 04:22 UTC#19
I dont mean to jack your thread, but how did you get your amp to power on? I'm having the same problem, and I've tried 2 amps, and tested all the power wires.
If you dont want to get off track, you could just send me a PM. I'm going away soon and I'd really like to know what the problem is.
Posted Feb 21, 2008 · 05:26 UTC#20
is the camera hooked up to switched power or is it hooked up to the reverse wire. the camera should be powered to a switched source, if not it will only work in "reverse" and not on map/split screen
