VSS and ECM for 2002 Tundra
By Dynatnt1 · Feb 14, 2008in Vehicle Specific Wiring💬 4 posts👁️ 866 views
Posted Feb 14, 2008 · 23:27 UTC#1
Okay, I have been doing research for hours now. I have figured out that my VSS wire is Green with an Orange stripe. It can be found in the ECM behind the glove box. I have even heard plug E4 2nd from left pin 5. Still do not see a green wire with orange stripe. My question is, where exactly is the ECM and which one is plug E4? Or is there is any other way to tell me where to hook in my VSS for a 2002 Tundra?
If you happen to know where the reverser wire is as well, I could use that also...
Thanks,
Toby
Posted Feb 14, 2008 · 23:41 UTC#2
why do people feel the need to post their question in every section?
Posted Feb 15, 2008 · 00:56 UTC#3
I only posted is two sections genius. I figured I would get someone somewhere to help. It fits in either category so I figured there may be certain people that can help. Didn't know there was a rule for posting the same question twice.
I am trying to install this right now and have run into a problem. I needed someone to answer right away.
Posted Feb 15, 2008 · 02:36 UTC#4
thats funny, i read it in three different threads, GENIUS! and the correct one was the vehicle specific wiring section. btw, you can also get that green/orange wire at the cluster in the brown plug
