Sprint Upstage
By bwolfe · Feb 15, 2008in General💬 6 posts👁️ 1,007 views
Posted Feb 15, 2008 · 17:57 UTC#1
Anyone using the Sprint Upstage with the bluetooth module on their D3?
I am finding it connects rarely and you can't really do anything with it.
If I have to bail and buy a new phone, what is the best phone and provider that works very well with the module?
I just didn't want to buy an expensive addon and not be able to use it. :lol:
Posted Feb 16, 2008 · 18:13 UTC#2
Sprint phones will be as inconsistent as any other provider, the providers do not dictate anything against the Pioneer Bluetooth module. The fact that it's hit or miss with all phones across all providers is not the mobile providers fault, but the fault of the handset manufacturer.
The Sprint Mogul works, with a registry edit for instance. It's all in the way the Bluetooth stack on the handset is implemented.
There should be a lot of Sprint phones that work. What is the problem you're having with the UpStage?
You need to be using Hands-Free profile not Headset profile. You'll have limited functionality with Headset profile.
Posted Feb 16, 2008 · 23:12 UTC#3
It works intermittently. It will connect and for awhile everything works. Then after a call or two, the speaker no longer works and it returns to using the phone,but the dialing and hang up options still work with the D3. Then it will disconnect and from there on out it wont connect and gives a connection error.
Once you clear everything and start over it will work, but then goes through the same scenario as mentioned above.
Posted Feb 16, 2008 · 23:46 UTC#4
never had a problem with my bosses upstage and the btb200 it does everything on all d3/btb200 battery life, signal strength, full phonebook transfer, voice dial.....everything never had a prob with it dropping either. my lg8700 sux like you wouldnt believe
Posted Mar 20, 2008 · 05:15 UTC#5
Yeah, I've had issues with mine too. Personally, I was not able to transfer my Contacts over all at once, I had to do them one at a time. It would lose its connection, come back etc. I could get the BT Audio to work, but then I'd lose that also.
jegonzo3
Posted Mar 28, 2008 · 00:57 UTC#6
My Sprint/Nextel radio phones usually don't play well with Bluetooth...The most common problem I had was the radio function (push to talk, beep-beep, whatever) didn't work at all when the phone was in B/T mode.
