BTB200 Possible Mic Issue
By bmoon1492 · Feb 17, 2008in Problems/Troubleshooting💬 7 posts👁️ 1,064 views
Posted Feb 17, 2008 · 18:32 UTC#1
I installed a new D3, Sirius, BTB200 yesterday in my Ford Explorer/
Everything works fine except for the BTB200. The mic does not seem to be picking up a signal. I've already checked all of the connections, reset the box, and switched phones to test it out - nothing...
Any suggestions as to how I can test the mic? I'm wondering if a mini plug headset would work?
Posted Feb 20, 2008 · 22:46 UTC#2
I am not sure but when I got mine installed it did the same thing, the shop had some wires mixed up.
I could hear them, but could not talk to them.
Posted Feb 20, 2008 · 23:35 UTC#3
Check the IP-bus connections. Make sure blue is plugged into blue, and black into black.
Posted Mar 01, 2008 · 17:17 UTC#4
Did you nick the microphone wire? Are you being careful to use only the mic that came with the Pioneer? Were you careful to mount the CDBTB200 as far as you can from other electronics in your dash, including the AVIC?
My installer made ALL of these mistakes. I had to order a new microphone from Pioneer, have another isntaller relocate the BTB200 in my dash, and then be careful to not nick the mic wire!
Posted Mar 04, 2008 · 06:37 UTC#5
i have the opposite, people can hear me but i can't hear them! whats going on here?!?!?!?!
Posted Mar 04, 2008 · 08:01 UTC#6
You put the P-bus cable in the wrong hole on the bluetooth box. Stick it in the right one
Posted Mar 04, 2008 · 08:38 UTC#7
wow, thanks, that helped alot! i went out there 2am in the morning and quickly ripped off the bezel (thank god its only clips) and redid the pbus and you were right. thanks.
