D3 and XM GEXP10XMT help. in an "updating" status.
By SVTandy · Feb 17, 2008in Problems/Troubleshooting💬 3 posts👁️ 530 views
Posted Feb 17, 2008 · 23:54 UTC#1
Hello all, installed the two units myself. the XM unit was a refurb. connected everything correctly:
D3 IP-bus blue connector to black IP-bus out on XM unit
data cable is connected to their respective ports on each unit.
power only(yellow) and the ground are connected. left the red ACC disconnected.
and the antenna is also connected of coarse.
I get the XM signal great. but I cannot get the xm to activate( all the channels), now the thing I noticed is that it is in "UPDATING" status since I plugged it in.
how long should it take to update the latest encyption code? minutes hours? and would that do anything for my activation of my account?
Posted Feb 18, 2008 · 01:18 UTC#2
Try pulling the car out into the open, leaving the XM turned on, and refresh the signal. You can do that either by calling XM or going to xmradio.com/refresh. I have seen it refresh in anywhere from a few seconds to like fifteen minutes. If that doesn't work, you have an issue with the box, or with the XM activation
Posted Feb 18, 2008 · 23:09 UTC#3
well, all was taken care of. the unit was a demo unit and was still active under said account. once turned off under the old account and reprogrammed under mine it worked fine.
