Help wITH VSS, Reverse sensor wire and location 2007 Sequoia
By thatdood · Feb 18, 2008in Vehicle Specific Wiring💬 5 posts👁️ 2,235 views
Posted Feb 18, 2008 · 20:32 UTC#1
I'm getting ready to install my 3rd AVIC D3 in my wifes '07 Sequoia but I need help finding a few wires.
Can anyone help me with color and location of the VSS, reverse sensor, and dimmer wires?
By the way this is the JBL audio system and I'm using the TYTO-01 Metra adapter. It appears the amp is located under the front of the console. Can anyone confirm if this is true?
Who would of thought this was going to be my most difficult vehicle? I still have to figure out how to get the rear DVD entertainment working... :)
Thanks in advance!
Posted Feb 19, 2008 · 02:53 UTC#2
Speed Sense green/orange ECM, 2nd plug from right, pin 8
The ECM (Engine Control Module) is behind the glove box.
Radio Illumination green + radio harness
Reverse Light red/black + driver running board near seat
Approximately 5 inches from B pillar.
Posted Feb 19, 2008 · 13:16 UTC#3
Thanks man!
Posted Feb 19, 2008 · 16:37 UTC#4
MisFit I also found information regarding the VSS behine the instrument cluster. Do you think this will be easier to access than the ECM behind the glove box? I haven't looked at the glove box but usually they are pretty easy to remove.
Posted Feb 20, 2008 · 02:21 UTC#5
I got about 95% of everything installed this afternoon. I ran out of day light before I could get the VSS and rear sensor connected but the wires have been run to the location of each connection. I spent most of my time tearing the center console apart trying to find a spot for the bluetooth box and the xm/nav/traffic box.
I was able to mount the bluetooth box under the center console and the xm unit went in the front of the console after removing the plate with 4 buttons.
The rear DVD entertainment still works but I'm thinking about running audio/video cables to it instead of using the RF modulator that it came with.
Thanks for your help once again.
