pioneer splash scrren image change
By geeoff · Feb 19, 2008in General💬 8 posts👁️ 1,663 views
Posted Feb 19, 2008 · 18:56 UTC#1
i'm new to this site and just installed a Z1 in my GLI. I'm sure it's on the forum somewhere, but I cant find it...how do you change that pioneer startup screen to a custom one? i know how to change the AV and VAVI backgrounds but can't figure out how to do the splash screen. Any ideas where I could find the info?
Posted Feb 19, 2008 · 18:59 UTC#2
That was an added feature to the Z2 I believe
Posted Feb 19, 2008 · 19:03 UTC#3
so that means I'd have to do the Z2 image upgrade?
Posted Feb 19, 2008 · 20:55 UTC#4
Ummm, if you want to change your splash screen
Posted Feb 20, 2008 · 22:33 UTC#5
ummm, maybe you shouldn't be such a s.a. I just want to know if there is ANY other way to get it done without messing with the HDD.
Posted Feb 20, 2008 · 22:42 UTC#6
If I remember correctly, on the Z1, the image is stored on the flash memory in the unit itself, not the HDD. Same for the Z2 actually, except the functionality to upload a new one to the firmware from disc or HDD has been added.
Even if it was just on the HDD, you'd still need to unlock it, so at that point there's nothing to stop you from upgrading to a Z2.
Posted Feb 20, 2008 · 22:44 UTC#7
thanks
Posted Feb 21, 2008 · 02:51 UTC#8
No, actually I believe the image is on the HD. People upgraded their Z1's prior to the Z2 release. However this still requires removing, and unlocking your HDD.
Easier to go all the way and upgrade to a Z2, where you get much better mapping system.
-Jeff
