Just as stated in the topic, I can not find the VSS wire or the reverse wire for my 2007 Kia Rondo. Any help will be greatly appreciated and thanks in advance!!!
Posted Feb 20, 2008 · 16:51 UTC#1
Speed Sense blue ac data link connector, pin 6
The data link connector is under the driver side dash. Also found at the BCM, 16 pin plug, pin 15. The BCM (Body Control Module) is above the brake pedal switch.
Reverse Light green + driver kick, 22 pin plug, pin 6
Thank you so much!!!
