GPS nav is off
By slicknick · Feb 20, 2008in Problems/Troubleshooting💬 13 posts👁️ 2,016 views
Posted Feb 20, 2008 · 17:41 UTC#1
When I drive down the road my arrow points to the right about 60-70 degrees. this causes my D3 to want to turn on all these streets, causeing inaccurate navigation.
How do I go about "recalibrating" or whatever I need to do. I was under the assumption that it just did it itself overtime, but it's been 100 miles and still no good.
thanks
Posted Feb 20, 2008 · 20:56 UTC#2
Do I have to take the unit out to reset this? can I just hit the reset and drive around.
Posted Feb 20, 2008 · 22:29 UTC#3
could it be that there is no metal plate under the antenna?
Posted Feb 20, 2008 · 22:32 UTC#4
Try resetting the 3d learning and distance studies.
Posted Feb 20, 2008 · 22:42 UTC#5
How do I accomplish that?
Posted Feb 20, 2008 · 23:50 UTC#6
"When the navigation system begins running for the first time, the 3D Hybrid Sensor automatically begins initial learning. Positioning is performed solely by GPS satellites until the 3D Hybrid Sensor initial learning is complete, so the location of your vehicle may not be very accurate. This is not an error. When the initial learning is complete, the location of your vehicle can be detected with high accuracy."
To clear values:
  1. [*:pslbw7gv]Touch “Settings†in the NAVI MENU, then touch “Hardware Infoâ€.
    [*:pslbw7gv]Touch “3D Calibrationâ€.
    The 3D Calibration screen appears
    [*:pslbw7gv]If you want to delete the learned results stored in
    “Distanceâ€, “Speed Pulse†or “Learning Statusâ€,
    touch the relevant result, then touch “Clearâ€.
Posted Feb 21, 2008 · 00:41 UTC#7
Yes
Posted Feb 21, 2008 · 03:16 UTC#8
thanks inferno, I reset all that stuff and drove to the store and back...lines up perfectly.
Posted Apr 22, 2008 · 00:55 UTC#9
What exactly does the metal plate do for GPS accuracy?
Posted Apr 22, 2008 · 03:46 UTC#10
It increases the reception sensitivity of the antenna.Better reception better accuracy.
Posted Apr 26, 2008 · 10:14 UTC#11
All that metal plate does is allow you to stick the antenna on a non -metallic part....like the plastic dash.
It doesn't effect reception.
Posted Apr 26, 2008 · 17:28 UTC#12
No, the plate acts as a ground plane for the antenna and does affect reception. You can use the antenna without the ground plane and sometimes you'll get decent reception anyway but you'll get better reception with it than without it.
Posted Apr 26, 2008 · 19:35 UTC#13
shoman94 read your D3 manual on the nav. antenna!
