Posted Aug 01, 2006 · 16:30 UTC#1
I have 1700 miles on my Z1 and the 3d calibration is still in simple hybrid. Left and right turns are full. Anyone have any ideas?
Mac3150 said:I have 1700 miles on my Z1 and the 3d calibration is still in simple hybrid. Left and right turns are full. Anyone have any ideas?
ducatiboy said:Mac3150 said:I have 1700 miles on my Z1 and the 3d calibration is still in simple hybrid. Left and right turns are full. Anyone have any ideas?
If your VSS wire is not connected or is confusing the Z1 then it will stay as simple hybrid. Do you have the VSS wire hooked up and on the connection screen (not the 3d calibration screen) does the VSS signal look like it changes with speed?
bongus said:VSS = Vehicle Speed Sensor. I believe the Z1 calls it the Speed Pulse. The speed pulse number should change with speed. I spoke to a Pioneer Support staff and he mentioned that as long as the pulse changes with speed , that is what the Z1 is reading. I'm still in simply hybrid mode and I have speed pulse data...not sure what is taking so long...I have over 170 miles.
niteone said:but, where can you see it change with speed? On what screen?
ducatiboy said:niteone said:but, where can you see it change with speed? On what screen?
MENU - SETTINGS (tab) - HARDWARE - CONNECTIONS
I think it's the top line or the second line down (if memory serves)
niteone said:so, on this screen, I should see something changing with the speed of my vehicle then I'll know it's hook up right, correct?
niteone said:
I know my speedometer on the AVIC-Z1 works, would that matter?
niteone said:
also, why is it important to get out of simple hybrid...why woudl that matter? Thanks, I'm learning here.
