how to turn on off pioneer avic z110bt
By HandsomeSteve · Jun 08, 2024in Problems/Troubleshooting💬 6 posts👁️ 748 views
Posted Jun 08, 2024 · 16:12 UTC#1
Posted Jun 08, 2024 · 18:41 UTC#2
I'm sure you can find installation and user manuals online. The unit has two +12vdc power sources. Yellow and Red  One is constant and the other is connected to an ignition switched source. That's how you turn it off (usually turn off the ignition).
Edited Jun 08, 2024 by RonS
Posted Jun 08, 2024 · 21:04 UTC#3
I'll rephase how to not turn radio on w/ ACC on?
how to turn radio off w/ engine on? do I have to add my own switch?
I am aware of the yellow constant 12VDC an red switched 12VDC. thanks for advising
Posted Jun 09, 2024 · 01:18 UTC#4
Press and hold the "Talk" button (just to left of Volume -+. This sets the AV source to Off. I don't know if that carries over after you restart via ACC Off.
Keep in mind that the unit is usually never completely off (unless the battery is disconnected). The red wire is a trigger to turn it on/off. So turning off the audio/video using the Voice button is the recommended way. If that doesn't suit your needs, then you could install an On/Off switch to the red wire.
Edited Jun 09, 2024 by RonS
Posted Jun 09, 2024 · 22:35 UTC#5
^"Press and hold the "Talk" button (just to left of Volume -+" all this did was mute volume
is there another button to left of volume? thanks
Edited Jun 09, 2024 by HandsomeSteve
Posted Jun 10, 2024 · 00:11 UTC#6
Well sounds like it's down to a switch on the red wire. I don't have a Pioneer anymore but I thought there was a way to select an Off source (which turns off audio and display). Might depend on the firmware version.
Edited Jun 10, 2024 by RonS
