I'm switching my AVIC from one vehicle to another. The old vehicle did not have a factory installed amp, the new vehicle has a factory installed "monsoon" amp.
With the original installation, I used the standard wires from the AVIC to the adapter for radio hookup. I believe these output a stronger signal. Now that the signal will be going through the Monsoon Amp (285 watts, I bellieve), should I use the RCA wires from the AVIC for the speaker wires?
If so, do they make adapters that go from RCA to straight wires for splicing?
A little more information. With the new system, the factory wiring has eight wires from the radio, marked low level audio signal to the amplifier (2 hot and 2 ground for front; 2 hot and 2 ground for rear). The amplifier then processes the signals and powers the four front speakers, the two rear speakers and a sub-woofer.
So, I’m guessing the larger RCA wires from the AVIC are low-level since they are designed to go into an external amp. Will this give better sound? Does it make much difference?
