AVIC Z2 Custom Background Picture
By jime2828 · Feb 22, 2008in Problems/Troubleshooting💬 7 posts👁️ 5,194 views
Posted Feb 22, 2008 · 07:42 UTC#1
I cant figure out how to burn a cd with pictures to set as a custom background, I already tried like 5 times, I know the cd must contain over 100mb of pictures and files and No audio tracks!
But I keep getting the "Import from disk" button greyed out!! Has anyone been able to do this?? :!::twisted:
Posted Feb 23, 2008 · 22:45 UTC#2
make sure the disc os over 100mb. also wait a few minutes. it takes some time for the unit to reconize the cd-rom
Posted Feb 28, 2008 · 15:32 UTC#3
That's not correct! It must contain over 100mb, but not pictures, etc.
Ok...here's what you need to do. Create a folder called "Pictures". Put your images you want to upload in that folder. Nothing else. Then, put 100mb of crap on the disk. I used several .pdf files. Burn the disk. So now I have a disk with a "pictures" folder with my .jpg images in it (that's the only file they will accept) and that's all that's in that folder...and a bunch of .pdf files that total over 100mb. Then follow the instructions. It will work like a champ. But your disk must be burned correctly.
Also, there is some blurb in the instructions about having to have the original disk you used to change the splash screen if you ever want to go back to default. Kind of weird...but I didn't read it carefully either. May want to read that!
Posted Feb 28, 2008 · 16:03 UTC#4
try just a few pictures on a disc, it worked for me. i also tried with about five discs and it didn't work, then i just put about 20 pics on a disc and it worked, i didn't need over 100mb of crap. try that. good luck.
Posted Apr 08, 2008 · 00:43 UTC#5
How long should I wait I have 25 .jpg in a folder named pictures and 140mb of junk on a disk my upload button is still greyed out any suggestions?
Posted Jul 15, 2011 · 19:13 UTC#6
i cant seem to get this to work... i tried 5 cds and still nothing
how should i be burning this and with what program should i use
