Z1 HDD Upgrade Help!!
By chillaxtodamax · Feb 23, 2008in Hacks/Mods💬 12 posts👁️ 1,991 views
Posted Feb 23, 2008 · 18:45 UTC#1
Hi guys,
so I'm trying to disable the security on a new Toshiba MK4026GAX drive, but when it tries to disable, it says "Device Error".
I turn Security off, then it writes the checksum, then writings changes to the drive, then I get "Device error"
Anyone have any experience? Did my drive somehow get locked?
Please helppppp!
Posted Feb 24, 2008 · 18:01 UTC#2
Anyone?
Thanks in advance.
Posted Feb 25, 2008 · 20:43 UTC#3
I've tried to disable the security on 3 computers now...
Packard Bell old old computer
Dell
my own built computer with AMD processor.
no luck :(
Posted Feb 25, 2008 · 21:20 UTC#4
I don't know what to tell you. I was able to disable security on the Stock Z1 hdd on my Dell Optiplex GX 270 with no problems.
Did you accidentally put the drive in the Z1/Z2? "even a drive you paid for seperately will be locked if inserted in the Z1. The drive doesn't even have to be setup to work in the Z1 to be locked. " If the drive is locked, you won't be able to access it in any way until it's unlocked. $45
If it's not locked, it's possible that it's not a supported drive, or that it's been damaged. First make sure you meet the requirements:
MHDD documentation[/url]":2a87qo4u]
Platform requirements and supported hardware
Platform:
  • [*:2a87qo4u]Intel Pentium or higher CPU[*:2a87qo4u]4 megabytes of RAM[*:2a87qo4u]DR-DOS, MSDOS version 6.22 and higher[*:2a87qo4u]Any boot device (USB, CDROM, FDD, HDD)[*:2a87qo4u]A keyboard
IDE/SATA Controllers:
  • [*:2a87qo4u]Any integrated into motherboard north bridge (addresses: 0x1Fx for primary channel, 0x17x for secondary channel)[*:2a87qo4u]PCI UDMA boards (detected automatically): HPT, Silicon Image, Promise, ITE, ATI and so on. Even some RAID boards are supported. In this case MHDD works with each physical drive separately[*:2a87qo4u]UDMA/RAID controllers integrated into motherboard as additional chip
Hard disk drives
  • [*:2a87qo4u]Any IDE or Serial-ATA drive with size bigger than 600Mbytes, in other words, LBA mode is supported in full. This is because I have removed whole CHS code since version 2.9[*:2a87qo4u]Any IDE or Serial-ATA drive with size lower than 8388607 TBytes, in other words, LBA48 mode is supported in full[*:2a87qo4u]Any SCSI drive with sector size 512—528 bytes
IDE drive should operate in master mode, and no slave devices should be attached. Please configure all drives you are planning to work with as master devices.
Posted Feb 26, 2008 · 15:16 UTC#5
Yea..I believe I meet all the requirements. I dunno if the drive is damaged, because it recognizes that it's a Toshiba hard drive and has all the specs show up when I "EID" in MHDD. Does it make a difference if I'm booting from a CD or floppy? because I been booting from Bootmagic, the CD.
edit: I never inserted the drive into a Z1. Also, I don't believe it's locked since the EID tells me that security is HIGH, Off.
Posted Feb 26, 2008 · 16:57 UTC#6
Try to set a password, if it says the device doesn't support that security feature, you're good to go. If it lets you, you did it wrong.
Doesn't matter if you booted from CD or floppy.
Posted Feb 26, 2008 · 18:40 UTC#7
how do you set a password?
thanks.
Posted Feb 27, 2008 · 05:41 UTC#8
i dunno, isn't that even in the instructions? i think it tells you to try setting a password to make sure security is disabled.
Posted Feb 27, 2008 · 14:53 UTC#9
I guess I can give that a try...
Since the EID still says "Security=high, OFF", I assume the security is still on.
Posted Feb 27, 2008 · 15:08 UTC#10
when you get to comand prompt
type in MHDD
Posted Feb 27, 2008 · 16:53 UTC#11
It's not that I can't get into MHDD. I can get in it, that's how I can find out the EID and such. That's not the issue.
It's when I'm disabling security, it says that it's writing to the drive, then "device error"
Posted Feb 27, 2008 · 19:55 UTC#12
I did it with the same instructions you are using... so I can only assume that it's your drive. Sorry I can't be more help.
